Sessions clock
Sessions clock
Another of my hobbies is clocks. I found a Warren Telechron mantel clock with basic hour and half-hour chimes for $5 at Sally's... (SA). Cleaned up beautifully and the original lacquer looks new. Only thing it won't do is chime at 12...
Last Saturday, I went to the same SA. Not only do I pick up some really good records but now clocks.
I added this onyx number for $13. More than I wanted to spend there but I couldn't look away from that deco face. Well, the rotor is shot. I cleaned it up and it's too nice to not run. I snagged another rotor on the 'bay with a different part number so I hope it works.
Try to find any information on these... year made, price new, etc...
Re: Sessions clock
Have you done the rotor lube process? The old-style ones lube up very nicely. One guy online dos it using a light bulb as heater but I prefer the soldering iron route.
Re: Sessions clock
That's the coil I took out of the robot so...
Re: Sessions clock
I like clocks too, but most of mine are windup. I do have three or four Hammond clocks.
Re: Sessions clock
I have 3 Telechrons, a 7F75 Nocturne, a 4H55 Statesman, a 7H141 Airlux and a Westclox Oracle. I also have 3 spring wound alarms, a'56 and '62 Travalarm and a 1949 Big Ben Loud Alarm. I also can't pass up "atomic" clocks when they turn up at thrift stores. I have 5 digitals and 2 analog face wall clocks.
Re: Sessions clock
Nice clockwork.
Some people bash my website, but I stand by the process. In fact, it is one of the "oldest" sites on the internet dedicated to rotor rejuvenation.
https://prepostmodern.com/rotors/
Re: Sessions clock
That's a good tutorial.
Re: Sessions clock
Thank you for posting that. The first one I did was by following very similar instructions. I had not been able to find it again. Yours gives the procedure and includes the oil dispersion steps.
Re: Sessions clock
Wow! I referenced your site when I restored my Warren Telechron. This sessions rotor has no guts, just that big coil. I did get this one working with a replacement rotor but I had to oil it about 10 times to quiet it down.
The bearing has a chamber that's filled with grease (probably whale blubber) and there's a tiny hole to the shaft. When the rotor heats up, the grease melts and lubes the shaft. I didn't want to take this one apart so I used the ZOOM oiler and let it seep in. So far, so good.
Re: Sessions clock
Thanks, Doc.. Now I just need to remember where to find your link here on the forum when I need it.
