1954/55 Motorola 54HF1 Unique Design
Post: # 6621Post Hi-Fi-Mogul »
I got tired of this gal looking at me saying:
"Why don't you at least clean me up ?"
I believe this was Motorola's "hi-fi in a hatbox"
answer to the Columbia 360.
The lid has a felt lining all the way around to
"seal" the baffle when closed.
I removed the cabinet lid yesterday, cleaned it and
did the 0000 steel wool and Howard's mahogany.
Drying outside for now. Much improved appearance.
There's a top corner of the lid that had a rat or similar
chewing on it. Not much I can do, but color the
exposed wood to match, after a bit of filing the wood
down a bit to even it out.
These era Motos have a nice escutcheon inside
the lid that says "Masterpiece by Motorola".
The matched burled wood cabinet face will look nice when
all cleaned up/touched up.
Today I removed the plinth/record changer, and
you can see it's yucky down there.
This tabletop Motorola has two down-firing speakers.
The cones look OK from a cursory viewing.
I hope they are functional.
I like the copper finish on the 50C5 PP amp.
Tubes 12AX7, 6C4, 50C5 x 2.
The V-M 950 was made in Sept of 1954, and the
shipping bolts were bent a bit, and will need
straightening up.
Tonearm contains an early Sonotone 2-T mono cart, of course.
The felt on the platter looks like mange, but I
think I have a spare platter.
1955 Motorola 54HF1-A .JPG (131.72 KiB) Viewed 11388 times
Re: 1954/55 Motorola 54HF1 Unique Design
Post: # 6623Post electra225 »
That will make a nice one, MR. Mogul. What do they use the 6C4 for? Phase inverter?
Post: # 6630Post William »
That's a cool looking unit, one I have not seen before. I'll look forward to seeing it restored.
Post: # 6635Post Hi-Fi-Mogul »
Greg,
Yes, the 6C4 is used as a phase inverter.
Bill,
I had seen a couple of these units, and I had
heard they sound very nice.
I'm finding it much more difficult to find
"good deals" on record players.
Some of the bidding is ridiculous is my book,
but then I'm a member of the "always buy
cheap" club.
And I have shifted away from collecting, to
restoring and selling, or repair work, for fun.
Post: # 6657Post electra225 »
The smaller record players could be had for only a few dollars three or four years ago. Now they want console money for them. The only way I'll buy them is if they are cheap. I get attached to things I take the time and effort to fix and get going again. I couldn't fix them up then sell them. Just not in my DNA. I hated to see cars I restored leave the shop.
Post: # 6662Post Hi-Fi-Mogul »
I am keeping my personal small collection of hi-fi's.
I do have one 1954 Capehart upright console that
I'll post about one day.
I have no storage space per se, and there are
about 7 more table top hi-fi's waiting for their
turn at restoration.
As slow as I go, I should have a year of time to
do the projects.
I do find a lot of satisfaction finding the right
buyers, who really appreciate the effort I
put into the record players.
Post: # 6666Post electra225 »
Being able to share your knowledge and ability with others by virtue of getting old electronic items into newer hands is an admirable activity.
Post: # 6685Post TC Chris »
Hi-Fi-Mogul wrote: ↑Wed Apr 06, 2022 3:15 pm I am keeping my personal small collection of hi-fi's.
A high school friend's family had a mono 1950s Capehart "Colortone" console. It used a V-M changer and had a number of tone controls--at least three, maybe more, on rotating levers (the levers probably turned regular rotating pots turned sideways). Seems to me it had a P-P 6V6 amp. Nobody ever played music on the thing so I never heard it.
Post: # 6735Post Hi-Fi-Mogul »
I have taken the V-M 950 completely apart,
when I saw its condition.
Due to its location over the tube amp, the old
grease was baked on about medium done.
But, it's cleaning up without undo elbow grease.
Rubber motor mounts completely missing,
and the idler is dry and cracked.
I've had good success using an O-ring for these
idlers.
I have a spare 33.3 RPM turret when completed.
Chris: I have always wanted a Capehart ColorTone after
viewing Chris Cuff's (RIP) video on it.
https://www.youtube.com/watch?v=4VTT28pbJcE
Post: # 6737Post William »
I see the Caphart has a VM changer too. :roll: ;) :)
Post: # 6747Post TC Chris »
The Capehart I saw had the same volume controls but was a console, blonde, with a V-M changer.
Post: # 6879Post Hi-Fi-Mogul »
I finished the re-build of the V-M 950 changer,
and cleaned up the cabinet.
The original Sonotone 2-T still works with
great output.
I used an O-ring for the idler, and a new
33.3 RPM turret from the Voice of Music.
But, when I played an old album, the
play speed for the new 33.3 turret is
around 40 RPM.
It is the correct physical turret, but the new rubber
diameter must have been mis-calculated.
It will go back to Gary for a replacement.
I checked the old 45 RPM turret, and it
played proper speed with a 45 record.
Next is to pull the amp for servicing, and
see if the torn speaker will mend with
glue/tissue paper.
Post: # 6908Post electra225 »
The cabinet looks nice, Mr. Mogul. I'm not sure I understand the benefit to a bottom-firing speaker. :oops: :?:
Post: # 6918Post Hi-Fi-Mogul »
electra225 wrote: ↑Wed Apr 20, 2022 1:54 pm The cabinet looks nice, Mr. Mogul. I'm not sure I understand the benefit to a bottom-firing speaker.
Greg, from what I have read (and hope to hear later !),
the sound emanates in 360 degrees this way.
Call it early surround sound, and again possibly a
market ploy to compete with Columbia 360 players.
Those CBS 360s had dual side mounted speakers.
The Columbias sound best to me when placed into
a corner, so the sound reflects off each corner wall.
Post: # 6921Post electra225 »
Thanks, Mr. Mogul. It's a neat little device and I look forward to sharing your progress. :D
Post: # 7127Post Hi-Fi-Mogul »
I removed the amp and speakers.
The woofer had a branched cone tear.
So, I used wood glue on one branch of the tear,
let it dry, then glued the other tear.
It doesn't look so good in the photo, but
the seams of the tears are nice and tight.
I cleaned that grimey chassis pending the
re-cap.
I am always out of 0.022 mF caps for some reason,
so a Mouser order is in order !
I may remove the Se rectifier body, to make
room for putting the filter caps
under the chassis on a terminal strip.
Post: # 7139Post electra225 »
AES handles service cement that I use on speaker tears. I don't generally have to reinforce the tear, just put it together then use the cement on it. That little amp chassis is full of bumblebees. You may have a fortune on your hands for the guitar amp guys. Could you use a new speaker in that player and still get the same sound? Or is is better to go with the repaired original? Not intending to second guess, just wondering. You can change the sound of a console not for the better if you replace the original speakers.
Post: # 7146Post Hi-Fi-Mogul »
Greg,
Does that speaker cement have a particular name ?
Someone cue me in on how to sell those bumblebees.
I had no idea, and "deleted", probably threw away some.
Yes, I always try to keep the OEM speakers, because
they are very efficient. Most modern speakers require
way too much input power to perform in these units.
And that is why I have about 10 speakers around here,
saved from trash units.
Post: # 7148Post electra225 »
It does have a name. Service cement by General Cement.
https://www.tubesandmore.com/search/nod ... e%20cement
Post: # 18039Post Hi-Fi-Mogul »
Well, I've had the V-M 950 record change complete for
about 8 months, ha ha !
This Spring, I cut off the capacitor can, and de-soldered
a BUNCH of wires and resistors left on the capacitor can.
Last week, I said this amp needs to be done.
As I sized the replacement e-lytic filter caps, I saw
I could not get even 2 caps to fit to restuff the can.
So, I drilled out the can rivets, and now I'm trying to
map out how to put in some new terminal strips and
how all the wiring will go.
The selenium rectifier took up a LOT of room, so it had
to come out, and could not be used for a tie point for
the 1N4007 diode I will install.
There are 3 bumble bee caps left in there that I'll
replace first, since they will be out of the way of
the other wiring, et cetera.
I was going nuts (or nuttier) for awhile, as the 12AX7
tube socket was not a 9 pin one, but a 10 pin one.
I could not figure out what that extra wiring was on
pin "9". Turns out it was Pin 10, and used for a
wiring connection point.
Man, I used up a lot of my cuss word inventory that night !
