Unobtanium soldering iron tips
I have two or three Radio Shack soldering irons I like and used until the tips burnt up. Of course, no RS here locally. What can be used to kluge new soldering iron tips? I thought about buying some heavy copper wire and using that...
Re: Unobtanium soldering iron tips
Greg,
Any pictures or model #'s ?
Every Radio Shack iron I have (or had) seemed to be a re-badged Weller.
I figured that they were heavy copper wire.
I can get some model numbers for reference. I never thought about the Weller connection. Are Weller tips still available?
Is this a pencel iron or a soldering gun ?
I was a radio shack in Indiana
Radio Shack & Osborne Electronics
Has a lot of old stock
Pictures of your irons would help
Happy new year
Douh6
Happy new year
Douh6
I was assuming pencil when I said copper wire, but my old Weller gun has the copper end that's basically a U-shaped piece of copper wire shunting the secondary of the transformer inside the gun. I bet a suitable gauge of copper wire, end pounded flat, would serve.
I have used #10,12 wire on gun shape it to make more contact on a larger connector.
#12 wire will turn red
You can find stuff on the web about that.
By the way they sell great lakes potato chips down here sw ohio.
Pretty good
Pretty good
One source....electra225 wrote: ↑Sat Jan 03, 2026 4:21 am I can get some model numbers for reference. I never thought about the Weller connection. Are Weller tips still available?
Go to eBay and type in "Weller Tip" in the search box......You'll get plenty of results.
