Magnavox Stereograph Deluxe
Post: # 23901Post Hi-Fi-Mogul »
This is model 2-SCS239, I believe from late 1963 to
early 1964.
Looking at the catalogs, there were different iterations of
the basic cabinet and changer.
This unit has left channel with an 8 inch oval speaker,
and the right channel with a 5 1/2 inch speaker.
Earlier versions had nice dual 8 inch coax speakers.
One had a woofer and tweeter for each channel.
I feel a little cheated out of those other speakers !
I've pulled the Micromatic and cleaned up the cabinet.
It came out pretty nice.
The engineers made the under cabinet access hole a bit too
far away from the Micromatic shipping bolt clip.
I spent an hour until I could get the clip flipped vertical
to remove the changer.
The transistor amp is on the right side of the cabinet.
When I received the Stereograph, I turned it on and the
amp was working and QUIET !
The original cartridge appeard to have output from
both channels, also good.
We have rain mid-week, so I'll start the dis-assembly
of the changer for cleaning during that time.
Re: Magnavox Stereograph Deluxe
Post: # 23905Post hermitcrab »
It appears to be in nice shape... different size speakers ? woofer on one side and midrange on the other?
Post: # 23906Post William »
My little Philco console has a 5X7 on one side and a 6" on the other with tweeters for both sides. It is a nice little console and sounds pretty good for what it is. VM changer, and single ended 6AQ5's.
Post: # 24185Post Hi-Fi-Mogul »
1. So, I ran into an "interesting" (not what I really said) problem
with the W604 record changer in the Stereograph Deluxe.
After sevicing the changer, on testing, the tonearm
returned to a position to the left of the tonearm rest
post, and dropped onto the changer base.
Nothing in the factory media about an adjustment.
I searched postings in several other forums, nada.
I had a "parts" Micromatic W604 fortunately whose
sub-plate/tonearm assembly was oriented properly
over its tonearm rest post.
So, I pulled that sub-plate to replace the original
in the Stereograph.
It works just as it should now.
2. I got to thinking that I could experiment with
determining what, if any, adjustment could be
made with the problem sub-plate/tonearm assembly.
During all this, I had looked at the two hex-head bolts
(#65-2 in the manual) that tied-down the tonearm
clutch assembly.
I slightly loosened the two bolts, and was able to
slightly move the tonearm pivot tube and nut
assembly counter-clockwise.
I re-tightened the two hex bolts down.
When I put the tonearm back on, it was
positioned to the right of the rest post.
So, at a later time, I'll tweak it again, to get
the tonearm position correct.
Then to check that the tonearm picks up properly at the
end of record lead out groove.
Post: # 24189Post William »
Interesting, and a good experiment that actually turned out well. Now all I need to do is remember what you did if I ever run into that situation. Thanks for sharing, Mr. Mogul.
Post: # 24213Post Hi-Fi-Mogul »
Today I placed the Micromatic back into the cabinet.
The little stereo gal sounds pretty darn good.
I did not expect it, but there is to me, very good stereo separation.
I was even able to flip down the retaining clips on the
shipping bolts (not easy btw, ha ha !).
StereoGraph Deluxe-1.JPG (419.89 KiB) Viewed 27934 times
Post: # 24228Post William »
It looks great, Mr. Mogul, and I like the ad you shared too.
