I had used this chassis as a dial cord pattern for the radio I just did the dial cord on. While I had that chassis out, I compared it to this one to make sure this chassis was complete, and it appears it is. I put a power cord on it, then plugged it in. No Variac, no KAW, no protection at all, just a hard start at full line voltage. It came on, both dial lights still work and I got an AM station right away. The thing sounds pretty good, all things considered. All the controls are dirty. As it plays, the audio is not as clear as it should be. Probably could stand a good recap. I'm amazed at this old thing. You can't kill this series of RCA radios. This one has the RC-1129A chassis. This set may be my next project if I can't get the courage up to dig into the SX-1050....
RCA model 6-RF-91 AM-FM radio
This radio is the bakelite cabinet version of the 6-RF-9. I bought two of these radios on ebay in the 1990's. They both arrived heavily damaged and were not the radios I thought I had purchased. I had a SNAD claim on these things if ever one existed. One cabinet was smashed into a million tiny pieces. The cabinet on this particular set was broken, but was able to be epoxied and somewhat put back together. It will take a lot of work to make it look decent, but I think it's doable. I have the spare chassis from the set that had the smashed cabinet. This set had no knobs, no back, the antenna was swimming around on the chassis, the power cord had been cut. It's been a shelf queen until this afternoon.
Re: RCA model 6-RF-91 AM-FM radio
I know you guys like pictures. I think this is my next project. Get this cabinet is shape good enough to paint. I have a full set of trim that is better than this from the other broken cabinet. I may not do the trim in gold. I haven't decided on colors yet. I connected the KAW after the initial power up. It pulls 62 watts at 118 VAC line voltage. I ran it a couple hours. It needs a good recap, particularly in the audio.
I am going to start a topic in "Cabinets and Grille Cloth" on the restoration of the cabinet....
I can't find a schematic for it. Does it have tuned RF amps on AM or FM?
Both bands have tuned RF. The front end is very robust in this series of RCA radio. It has two stages of IF on each band. The Zenith guys seem to think the C-845 series of Zenith radio was the best table radio. This series of RCA sets will outdo them in almost every category, IMHO. The Zenith sets have a selenium rectifier and are plagued with SMD.
