This afternoon I was building a redwood shelter around an outdoor electric outlet. I had the GE Superradio III by the work site and also turned on the garage radio, a little Radio Shack 12-684 AM-FM table radio so I would not miss the evening news show. The RS radio's volume control was almost nonfunctional. Spritzing it with control cleaner was a "some day" chore. Today became the day. Of course there were hurdles. First, the cottage's can of control cleaner had no gas pressure left. So I wondered about poking a hole in the can. What if there is pressure and it's just a plugged valve? Will it explode? But I worked up my courage and poked a hole. Nothing exploded, and I got some liquid cleaner out and dripped it into the control with a knife tip.
But every job has the unanticipated fix. As I was putting the back on, both wires to the FM antenna terminals broke. Of course. Happily, the cottage has a small pencil soldering iron and some rosin-core solder, so that got fixed.
And then there's the crackly tuning. It has one of those plastic-encased tuning caps, so there's no way to de-oxidize the ground contact like you can with an open-frame unit. I'll live with it.
It's an interesting radio, with a small but large-magnet speaker in a sealed chamber with some fiberglass stuffing around it. Not high fidelity, but better sound than you might expect from a small inexpensive device.
Radio Shack 12-684
Re: Radio Shack 12-684
Your day of fixes sound like mine, Chris, one step forward and two back.
