Jackson 648-S tube tester died
Post: # 22610Post electra225 »
This was my stepdad's old tube tester from when he had his TV repair shop. I was testing a tube then the filament went out. When I turn the tester on, it will center the meter, but I don't have any filament voltage for tube testing. I didn't find a fuse and the schematic pasted to the cabinet doesn't show one. Anybody have an idea where to look?
Re: Jackson 648-S tube tester died
Post: # 22611Post Hi-Fi-Mogul »
Greg,
Here is a nice write up on the Jackson 648 series testers.
Towards the end of a rather exhaustive review of his
tester, he says there is no fuse.
https://tubesound.com/rebuild-calibrati ... kson-648a/
Post: # 22612Post electra225 »
I like your avatar, Mr. Mogul. Thanks for sharing it...... :D :D
Thank you for the link. That will give me a place to start.
Post: # 22613Post hermitcrab »
are all the tube filament voltages dead?
Post: # 22618Post William »
That is a cool Avatar, Mr. Mogul.
Post: # 22621Post Hi-Fi-Mogul »
Greg and Bill,
When I saw that "Hi-Fidelity Incorporated" photo,
I knew that's where I wanted a job.
Now, if I can only find that time machine I had
around here....
Post: # 22631Post William »
When you find that time machine, I would like to borrow it. :roll: :lol:
Post: # 22677Post electra225 »
I have no filament test voltage. I have AC up to at least the primary of the filament transformer. The plate and screen voltages work fine, and use a different power transformer. There is a switch "S2" that I can't find. It is called the "filament switch". The only filament switch I see is the round one where you choose which filament voltage you need. This switch is drawn on the schematic as a regular old switch, not a switch with several positions. Hmmmm. :oops: ;) :cry: :roll: :shock: :cry:
Post: # 22678Post electra225 »
Bummer. The filament transformer is out. :cry: :cry:
Post: # 22679Post William »
Another transformer malfunction does that mean a transformer or is there a work around for this problem. I sure hope it is a simple fix.
Post: # 27578Post electra225 »
Well, now I don't know what to believe. I initially thought the filament transformer primary might be open. Now, I'm not sure about that. It "ohms out" good. The only schematic I have is the one pasted to the bottom inside of the cabinet and it's not the best. According to that schematic, if I read it right, power goes from the line, thru the primary of the filament transformer and the other transformer, then thru the "filament" switch, S2. I have determined that S2 is the "life test" switch. I seem to be getting AC thru the filament transformer primary, but not thru that silly life switch. I am not 100% sure how to troubleshoot that. This thing quit suddenly. No smoke, nothing smells like it's been hot, nothing looks burnt.
Post: # 27988Post hermitcrab »
The life switch on mine is a momentary slide switch , it places the tube under a load as if it were in a circuit, I wouldn't think that would have anything to do with the Filament voltage, but they made so many variations of the 648 , it could be possible.
Post: # 30245Post electra225 »
I've been putzing with this thing some this afternoon, deciding whether to toss it or not. That S2 switch I was looking for is the "life" switch. It's okay. Something strange is going on. The primaries of both transformers seem to be okay. The multi-position filament voltage switch is a mystery to me, how to troubleshoot it. It seems like the secondaries of both transformers may be where the issue lies. And, since I don't see a rectifier anyplace, I am to assume that all the voltages in this instrument is AC? That doesn't seem right. Maybe I need a schematic better than the one pasted to the bottom of the cabinet. What am I overlooking? The issue has to be something simple.....
