1960 Sylvania Portable w/Uncommon Changer
Post: # 22263Post Hi-Fi-Mogul »
My jukebox expert friend gave me this 3 tube + SS rectifier
Sylvania "Golden Shield" model 650.
Tubes are two 50C5's and a 12AX7.
L/R channel Vol controls, no Tone controls.
It's a curious little player that has an original Telefunken TW501
record changer made in West Germany.
It came with the original owner's manual which verifies the changer.
The cycling mech is similar to a V-M, and I have read in other forums
that there was a licensing agreement b/t the two.
The second stereo speaker is in the lid as was commonplace for
these little stereos.
Sylvanic 650 Stereo.JPG (480.9 KiB) Viewed 59804 times
Re: 1960 Sylvania Portable w/Uncommon Changer
Post: # 22264Post electra225 »
Could that stereo have been built by Telefunken for Sylvania?
Post: # 22309Post Hi-Fi-Mogul »
electra225 wrote: ↑Sat Jul 20, 2024 12:05 am Could that stereo have been built by Telefunken for Sylvania?
I opened up the chassis and all the components are U.S. as
are the tubes (Sylvania ones).
Someone had replaced the e-lytic caps, but it is a
messy job.
So, I'll need to double check that.
There is a small schematic pasted on the cabinet
inside, but my camera won't take a clear enough photo.
Two old wax/paper caps were not replaced.
Post: # 22311Post William »
I find it interesting how much the changer looks like a VM, and with what you said it is probably a VM with an odd-looking motor.
Post: # 22313Post Hi-Fi-Mogul »
I looked over the messy amp and the e-lytic caps appear to be
in correct positions.
I connected the changer to the amp and turned it on.
The original cartridge has good outut for each channel.
Problem: after 60 seconds, the tube filaments go dark.
The record changer motor is still working.
I let the amp sit for 15 minutes, re-energized it, and
the same behavior with the filaments.
I tried moving the tubes in their sockets, no filament power.
All tubes 50C5s, 12AX7 tested good.
1. Does this appear to be a heat-related component
failing ?
2. I don't think it is a connection problem with the
tubes, due to re-producing the symptom of no
filament power.
I can't post a schematic until I can get a better
camera, but your input is appreciated.
Post: # 22314Post William »
I had something similar with a Silvertone that was VM influenced. It drove me nuts, I just could not see a problem by looking for a bad connection or the like. Finally, one day while I was trying to follow wires and testing voltages, I noticed a wire that was attached to a pin on a tube socket. Low and behold, the tab where the wire attaches had broken off the actual contact part that contacted the tube pin. After a good wiggle it let loose and fell all the way out. Come to find out these tube sockets were the cheapest of the cheapest and actually both output tube sockets and the rectifier socket had that problem. The pre-amp tube socket was ok. Needless to say, I replaced all 4 with good sockets and have not had an issue since.
Post: # 22315Post electra225 »
It appears that this record player has two 120-volt "filament" strings. One for the phono motor, one for the tube filaments. Even though you have tested the tubes in a tube checker, my suggestion would be to sub the tubes to see if they still go out. My experience has been that 50C5 tubes run really hot. Your tube tester may not put enough voltage on the tube to get it as warm as it does in service. My thinking is that a tube filament is heating up and opening after it runs for a short while. You could sub them one at a time, or all together then replace them one by one with the originals until you find the one causing the trouble. You could also check where the two filament strings split. The one that goes to the motor is obviously okay. Check for bad connection or a cold solder joint. Good luck.
Post: # 22318Post Hi-Fi-Mogul »
electra225 wrote: ↑Mon Jul 22, 2024 11:25 pm Even though you have tested the tubes in a tube checker,
Greg, you nailed it.
When I was testing the tubes, I thought I saw one of
the 50C5's go dark and thought it was the tester socket.
It must have come back quickly, as it tested 95/100 good.
I subbed out a good 50C5 for each of the original tubes.
It was the one original Sylvania that was bad.
Thanks to you and Bill for the suggestions.
Post: # 22320Post William »
Glad you got it sorted, Mr. Mogul. Sometimes simple things can be hard to find.
Post: # 22321Post electra225 »
Glad to hear you got it fixed. For God's sake, don't buy any 50C5's. I have enough to do me and ten of my closest friends three lifetimes. I have hundreds of them, probably 300 or so. I don't remember when I replaced one the last time. The radio guys give them a bad rap, but they have proven rugged and reliable for me. Gas, grid emissions, and intermittently open filaments have been their top concerns in my experience. I don't believe I have ever replaced one for just being weak.
Post: # 22327Post Hi-Fi-Mogul »
I was able to take a passable photo of the Sylvania schematic.
As is common, part of it is missing.
Would someone give me and idea of where the center
tapped connection b/t the 2 output transformers may
be going ?
I see it heading to the power supply filter caps section.
Until I undo the rat's nest of the replaced e-lytic caps,
I'd be curious to know.
Thanks !
Post: # 22330Post electra225 »
That connection to the output transformers is not a center tap. The transformers are connected together at B+. The wire from that connection goes to the second filter cap. The grids are fed from the same point. The output transformers drop B+ a few volts, so the grids run higher B+ voltage than the plates. The cathodes connect to chassis thru resistors. There is no cathode bypass cap, per se. Common negative is floated above chassis thru a .05uf cap.
Post: # 22331Post Hi-Fi-Mogul »
electra225 wrote: ↑Wed Jul 24, 2024 2:59 am That connection to the output transformers is not a center tap.
Wow, that was a great explanation of the amp's
architecture.
Many thanks for that helpful guide.
Post: # 22333Post TC Chris »
electra225 wrote: ↑Wed Jul 24, 2024 2:59 am That connection to the output transformers is not a center tap. The transformers are connected together at B+. The wire from that connection goes to the second filter cap.
Although maybe there's a 2nd resistor in the area that's damaged on the schematic?
Post: # 22338Post electra225 »
I wondered that same thing for a moment, Chris. I don't see why they would put a resistor there. The output transformer will drop a few volts anyways. They don't want the plate voltage appreciably lower than screen grid voltage. This can be verified by measuring B+. If B+ to the plates is, say, 15 volts lower than that to the screen grids, then, yes, there may be a resistor there. If the plate voltage is only 5 volts or so lower than that on the screen grids, then no resistor. And, he can look at the chassis to see if there is a resistor present.
Post: # 22344Post Hi-Fi-Mogul »
There is a large 10 watt 50 Ohm resistor underneath
all the capacitor confusion.
I'll know more when I get around to tracing the wiring.
I'm going to get the Telefunken working right first.
Post: # 22345Post electra225 »
I would suggest that the 50 ohm, 10 watt resistor you see might be the one listed on the diagram as 47 ohms, 7 (?) watts, just before the rectifier. They wouldn't have a need for a ten watt resistor in the B+ line to two output tubes.
There is a 50-watt (nominal) resistor ahead of the rectifier in the line. Then there is a 100 ohm resistor between the first filter cap and the second filter cap. I'd guess they want the B+ to the output tubes around 100 volts, give or take. I don't see a spec and haven't done the math, but that will be close. If you have 120 volts on the line, add in the 50 ohm resistor, that will give you 115 volts or so at the anode of the rectifier. Consider then the 100 ohm resistor between the filter caps, that might give you 105 volts to the plates, minus a couple volt drop thru the output transformer primary. You should have similar voltage to the screen grids, plus the couple of volts drop thru the output tubes not present to the screen grids. Approximately....... ;) :oops:
Post: # 22483Post Hi-Fi-Mogul »
I have the amp out for service completion.
Two original 0.05 mF caps to be replaced and
the e-lytics to be re-wired.
The old selenium rectifier is not secured to the
chassis and will have a 1N4007 replacement.
I'll put in a terminal strip to try and make this
all neater than what the last guy did.
Post: # 22486Post William »
Kind of reminds me of the little Philco stereo amp I worked on, very cramped but with patience doable. Good work, Mr. Mogul.
Post: # 22564Post Hi-Fi-Mogul »
Well, I finished getting the caps and rectifer
all wired up using a vertical terminal strip.
Sound is good, but the dang Telefunken tonearm hangs
up at the end of the record.
Some sort of fine binding, which I cannot find.
The amp location does not allow much ventilation for
the two 50C5 hotties there.
The plinth is super hot, not good design, Sylvania !
Overall, I'm a bit disappointed in this one, but I learned
a lot about Telefunken changers.
I won't be able to sell this, so I'll donate it to Goodwill.
