Cordless Solder iron
Post: # 21327Post hermitcrab »
Picked this up on a whim from temu was like 8 bucks and free shipping from China ... this thing works awesome , charges up with a USB cord in about 10 mins , and they claim it will last about 30 mins on highest setting , but I never tested it for that long , but this thing gets hot like right now... and is perfect for taking the iron to the piece instead of dragging out an extension cord to get to where you are working ... well worth the price , been using it on the little GE to install the new caps ...I like instead of temps they say first gear, second gear, and third gear... and they obviously can't spell blue... :D
Re: Cordless Solder iron
Post: # 21328Post William »
That's pretty cool, where did you get it?
Post: # 21329Post walyfd »
That'd be handy for car work. Looks like it's worth 8 bucks.
Post: # 21330Post hermitcrab »
William wrote: ↑Sat Apr 27, 2024 8:37 pm That's pretty cool, where did you get it?
TEMU.... I have been buying my woodworking stuff from them , so far everything works great at 1/3 of the price ....just takes 2 weeks to get to you...yes it would be great for working on the wiring in your car ....
Post: # 21331Post William »
Thanks, Elton. I have never heard of Temu, I guess I had better get on Mr. Google.
Post: # 21410Post Hi-Fi-Mogul »
How many replcement tips come with the item ?
Are replacement tips available ?
Post: # 21431Post hermitcrab »
Hi-Fi-Mogul wrote: ↑Fri May 03, 2024 4:27 pm How many replcement tips come with the item ?
Only comes with the one tip, not sure if there are replacements for it...
Post: # 21463Post Hi-Fi-Mogul »
Thanks for the information.
