Mono Westinghouse & Motorola
Post: # 20700Post Brettzky99 »
Picked up a couple of late 50's mono sets.
Keeping them both...the Motorola gives me a 58, 59, 60 and a 64.
Re: Mono Westinghouse & Motorola
Post: # 20704Post electra225 »
I can't own a blonde anything, but I really like that blonde Westinghouse. You are fortunate to have found two in such great condition. I hope you'll share the restoration work, if any, with the forum.
It's good to see you on the forum, Brett. Please make yourself at home..... :D :D
Post: # 20706Post TC Chris »
OK, now let's see pix of innards!
Post: # 20708Post William »
Wow, another blonde find, good job, and both are keepers. I am familiar with the Motorola, that model sounds great. Like Chris, I can't wait to see the backs off of both of them especially the Westinghouse.
Post: # 20711Post Brettzky99 »
Motorola 6V6
Westinghouse is 6L6
Post: # 20713Post William »
Nice! Big PT's on both and the OPT on the Motorola is impressive too. Westinghouse was going for power using 6L6's. The Westinghouse even uses separate components like the Motorola.
Post: # 20717Post Brettzky99 »
William wrote: ↑Tue Mar 26, 2024 12:31 am Nice! Big PT's on both and the OPT on the Motorola is impressive too. Westinghouse was going for power using 6L6's. The Westinghouse even uses separate components like the Motorola.
They're both restored. Dave G helped do the final checks and with some resistor work. Monster sound. Is there a anywhere to upload videos?
Post: # 20718Post William »
I'm not sure on the videos, Brett, maybe Greg will chime in with an answer.
Post: # 20726Post electra225 »
To be honest, I don't know. :oops: :cry:
I know Chris posts to YouTube, then links the video. I don't know enough about such things to advise you how to try. Chris might be the man to advise you better than I can. I know we can't post PDF files on the forum, other than in Downloads. I don't know if you could cut and paste a video on the forum or not.
The Westinghouse has some impressive iron. I'm surprised that Westy used such exotic livery in a record player. P-P 6L6's are good for 40 watts or so, aren't they?
Post: # 20727Post TC Chris »
The 6L6 outputs are usually at around 20 watts.
And yeah, I upload videos to my YouTube channel (doesn't that sound impressive, "my channel"?). I usually have to climb the earning curve each time because I forget how I did it last time but it's less daunting each time. YouTube takes you through a bunch of steps. Check "not for children" on anything you are uploading of an ordinary nature. They review your upload to see if you've got copyrighted music playing for more than a snippet. Some of it is allowed by the holder; some isn't. They'll tell you. Make sure you check "public" as opposed to "private." I blew it on my last try, and figuring out how to make it "public" again took longer than uploading.
Once it's uploaded and published and public, they'll give you the URL link and you can share that with us.
