TEAC T-R670
TEAC T-R670
Post: # 19173Post 19&41 »
I found a decent AM/FM tuner at the goodwill for $5 and after hearing it call for me while shopping, I had to bring it home. My Magnavox accessory tuner for the Hepplewhite is not as sensitive as I would like, so I use a digitally controlled tuner and a Terk amplified antenna with it to pull in the Atlanta stations. I've gotten the instruction manual from manualslib.com, now all I need is a remote to make it complete.
Re: TEAC T-R670
Post: # 19176Post hermitcrab »
Got a picture of it?... I think I have a teac tuner in the basement somewhere.... A really thin unit if I recall...
Re: TEAC T-R670
Post: # 19177Post 19&41 »
Here's a link to a picture on Bing.
https://www.teac.co.jp/content/images/u ... 1/main.jpg
Re: TEAC T-R670
Post: # 19181Post hermitcrab »
Yea mine is different , like 2" tall ,and weighs nothing, no thicker than the display of the unit in your picture ... I do have a box of remotes... I never throw them out , I will dig it out and see if I have one ...
Re: TEAC T-R670
Post: # 19185Post 19&41 »
Thanks! This unit is heavier than the one it is replacing. I can get more FM stations with it also. It can pick out a few AM stations on the inside antenna when the lightning is out and I disconnect the long wire antenna from the console's radio. There are component groups that pass through the Goodwill stores around here periodically. There wasn't anything else with this.
Re: TEAC T-R670
Post: # 19197Post hermitcrab »
Unfortunately no Teac remotes , but one I have is laid out almost identical to the remote in the picture, but it is for a optimus RS receiver... but I seem to recall hearing that Teac was a supplier for RS equipment back in the day?...
Re: TEAC T-R670
Post: # 19208Post TC Chris »
Remember that even very good tuners need a competent antenna. People often hook up the folded-dipole antenna that comes with the device and throw it behind in a jumble of wires. Not good. At the very least, tack it outstretched on a piece of lath, and find a vertical or horizontal orientation that works well for the stations you prefer. That's what I use at work. In my old space I had it hanging from the sprinkler system pipe. At the new office it sits vertically. Of course, a rooftop antenna is better, either an omni or a directional version as the situation may demand.
Re: TEAC T-R670
Post: # 19216Post 19&41 »
hermitcrab wrote: ↑Sat Jan 13, 2024 5:56 pm Unfortunately no Teac remotes , but one I have is laid out almost identical to the remote in the picture, but it is for a optimus RS receiver... but I seem to recall hearing that Teac was a supplier for RS equipment back in the day?...
Thanks for looking. I've made a bookmarked Ebay search for the tuner and it's accessories. I'll keep checking til something comes up.
Re: TEAC T-R670
Post: # 19217Post 19&41 »
TC Chris wrote: ↑Sat Jan 13, 2024 9:07 pm Remember that even very good tuners need a competent antenna. People often hook up the folded-dipole antenna that comes with the device and throw it behind in a jumble of wires. Not good. At the very least, tack it outstretched on a piece of lath, and find a vertical or horizontal orientation that works well for the stations you prefer. That's what I use at work. In my old space I had it hanging from the sprinkler system pipe. At the new office it sits vertically. Of course, a rooftop antenna is better, either an omni or a directional version as the situation may demand.
The higher the better is the key here. The topography is like a ripple pattern from a drop into standing water, with the city at the center. Without doing wall work with fish tape and the like, the Terk will have to do for the time being.
