1950's AMC Blonde Tabletop
Post: # 15226Post Hi-Fi-Mogul »
This is one of 4 players I have removed from the
garage, due to the intense heat wave.
I bought it in March, somewhat locally, and I
do believe this is a Columbia-made record player.
The cabinet is very well made and wood heavy.
The amp, controls, speakers, and cabinet are very
similar to the Columbia 360 Mk II from 1953.
I'll confirm later when I pull the amp.
Re: 1950's AMC Blonde Tabletop
Post: # 15234Post William »
Well, I have a very similar unit but mine is branded Silvertone. As you can see by the link what's under the hood is identical:
https://www.radiomuseum.org/r/sears_roe ... 54840.html
To continue, I believe both yours and mine were built by VM, as it is the same as the VM model 555. When I was researching mine back when I first got it I came across this link:
https://www.antiqueradios.com/forums/vi ... 9&t=276856
Here's a couple of photos of mine:
Post: # 15235Post Hi-Fi-Mogul »
Bill,
That's fascinating about your Silvertone.
I like digging up hi-fi history.
The paper schematic that was glued on the AMC cabinet
bottom is gone.
If you have the schematic for your Silvertone,
please post it for me.
The V-M 555 chassis looks different and uses
3 speakers.
But, I'll check/compare the components the day I pull the amp
out. (no start date given !)
I asked Gary about the V-M code under the 954 changer.
He said it was made for Audio Industries, who made
many units for retail re-branding in department stores.
I know our regional Foley's Dept. stores sold AMC
branded products as their store line.
So, I think our two might be AI origin.
AI also branded as Amcrest for some products.
Post: # 15240Post TC Chris »
There must have been a thing for those P-P 35l6 phonos with two speakers and a V-M changer. I've got an Emerson 820B portable with side-firing speakers.
https://www.radiomuseum.org/r/emerson_8 ... b_120.html
It too had been retrofitted with a Sonotone stereo cartridge. I mostly used it as an amp and speakers for a portable sound system, driven by my Sony 350 tape deck that fits perfectly inside and old suitcase for travel. Pre-Walkman, pre-iPod, pre-cell phone, that was the only way to carry music around. A few times I carted it to work when I was a grad student with a nighttime library job on campus.
That one ought to be in the resto queue.
Post: # 15244Post Hi-Fi-Mogul »
Chris,
That is very interesting about your Emerson.
I have 2 Columbias in the exact same cabinets as yours.
They are in the queue (long queue).
And for those several years, it was the Hi-Fi in a Hatbox
era.
Post: # 15246Post William »
Somewhere, back when I was researching my Silvertone, I came across something that said these units were offered with either two or three speakers. If two, they were 6". If 3, they were 5". I wish I had printed that off to keep with my records.
A word of warning. If yours is like mine, the tube sockets are junk. I had mine all restored, and it was playing perfectly. Then one day the Silvertone came up in rotation to be played. I put on a few records, hit reject, the records dropped, the tone arm landed, and nothing. No sound at all. Out comes the amp and I start looking and testing. I find nothing, absolutely nothing wrong. I look and test again. Nothing! I tested the tubes again and they were good, and they are glowing in the unit as well. This does not make sense. I find nothing wrong. Out of frustration I set it aside and after several weeks I came back to it. As I was poking around, I noticed the tubes were not glowing. Interesting, I must have moved something as I'm poking around. I started wiggling things and the wire that is in the heater string fell out of the tube socket. As I started pulling on all the wires that were soldered to tube socket pins, more and more started falling out. To the eye, everything looked OK as there must have been just enough friction to hold the soldered point in place but yet they were broken off inside the socket itself. New sockets were ordered, the good kind, sockets replaced, and all is well.
Post: # 15247Post Hi-Fi-Mogul »
Bill, do you have a model number for your Silvertone ?
And thanks for the speaker option info and
the heads-up on the tube sockets. [ : )
In fact, this week I'm going to see a friend down
the street who does have a 3 speaker Silvertone !
I wanted to look underneath his to see if there was
a schematic glued on the bottom.
The AMC schematic is long gone from its
spot under the cabinet.
Post: # 15249Post William »
I do, it's 47421. I have a Sam's for mine and I will be happy to share it with you. Please check your PM's for further information.
Post: # 15250Post Hi-Fi-Mogul »
SUPER !
Post: # 15276Post William »
Mr. Mogul! What does it say in the upper LH corner on your first photo? It looks like it was a decal, that's missing.
Post: # 15284Post Hi-Fi-Mogul »
William wrote: ↑Sat Jun 17, 2023 12:54 am Mr. Mogul! What does it say in the upper LH corner on your first photo? It looks like it was a decal, that's missing.
Bill, that decal says "High Fidelity", of course !
It is a bit faded, but still cool that it's there.
Post: # 15334Post Firedome »
That's a well-made looking player. I think AMC was the department store buying association called Associated Merchandising Co. that many stores belonged to to allow for bulk-buying power. AMCrest was a name used for radio/stereo products iirc. Out local Dept. Store Hutzler's was an AMC member one my wife worked there during college circa 1970, I recall seeing the AMCrest name on stuff they sold, the had a furniture dept that sold console stereos. I'd love to be able to go back in time and look at them in their showroom! Hutzler's was high-end and sold nice stuff.
Post: # 22817Post Hi-Fi-Mogul »
Last week I went through the V-M 954 changer mechanism
and motor, for cleaning, new grommets and motor mounts.
It works well, but the trip link needs an adjustment,
because the tonearm does not pick up at the end of
a record.
I'll look into that tonight.
I removed the original dead crystal turn-around cart.
I drilled a hole to mount the new Pfanstiehl P-228.
The PP amp had a lot of cadmium oxide on it.
Today I put on a mask and gloves and cleaned
the chassis outside.
Using some small pieces of a cotton rag, I applied
a thin layer of oil over the chassis, and wiped it off.
V-M 954-1.JPG (370.03 KiB) Viewed 52384 times
V-M 954-2.JPG (332.69 KiB) Viewed 52384 times
Post: # 22818Post William »
Looks good, Mr. Mogul, you do nice work.
Post: # 22819Post electra225 »
I can get a VM changer working well. For two weeks. After it sets for two weeks, it won't work. I take it apart, don't see anything wrong, put it back together and it works fine. I have to be overlooking something, but it's not the same issue every time. ;) ;) :oops: :oops: :roll: :roll: :cry: :cry:
Post: # 22821Post William »
My guess, and this will sound bad, you are not getting them clean enough. Then when you take them apart you have moved the linkages which is enough to loosen things up until it sits again.
Post: # 22823Post electra225 »
That was kinda what I thought. I don't know how to get them cleaner than I am. I reckon do it until I think it is clean, then clean again. I'll just have to take more time and be more patient. The next problem will be forgetting how things go back together...... ;) :oops: :cry: :roll:
Post: # 22824Post William »
Remember to take photos with each step. I am lucky, I have a bunch of VM changers I can use for comparison purposes. Like most things, the more you do it, the easier it becomes.
Post: # 22825Post electra225 »
It seems like the more I do it, the more problems I create...... ;) :( :oops: :? :roll: :lol:
Post: # 22828Post William »
You will get there, just give it time.
