General Electric "Trimline" stereo model RP-2040A
This is the basic, bottom-of-the-line little GE "Trimline" stereo. I have three Trimlines, the ones I got from Don. This one is a three-tuber, 50DC4 rectifier and one 35EH5 output tube per channel. It has volume, balance, and tone controls. The cartridge is a flipover crystal Ronette, model 208-1 and, of course, it's kaput. It has a 1200 series Voice of Music changer with a nine-inch platter. It has two six-inch speakers, the ones they use commonly in GE stereos, coded 137, Chicago Telephone Supply. I don't see date codes, but I have only seen one speaker. The tubes hang upside down and are a bear to get back in, so I haven't pulled them yet. It has been recapped at some point, but it needs filters at least, as there is considerable hum in the audio. The handle is broken/gone, but I think a guitar amp handle will work just fine. It needs one of everything, but overall, it is not in bad shape. The paint is sticky from cigarette smoke at some point and the grille cloth is nasty. The cabinet is a textured aluminum that can be disassembled, washed in a parts washer, walnut-shell bead blasted, then repainted. I want to see if Gary can provide a cartridge that will work before I put more time into it. Pictures are in production, but you get the text first.
Re: General Electric "Trimline" stereo model RP-2040A
I can't believe I just saw this post now.electra225 wrote: ↑Thu Apr 20, 2023 7:29 pm This is the basic, bottom-of-the-line little GE "Trimline" stereo. I have three Trimlines, the ones I got from Don. This one is a three-tuber, 50DC4 rectifier and one 35EH5 output tube per channel. It has volume, balance, and tone controls. The cartridge is a flipover crystal Ronette, model 208-1 and, of course, it's kaput. It has a 1200 series Voice of Music changer with a nine-inch platter. It has two six-inch speakers, the ones they use commonly in GE stereos, coded 137, Chicago Telephone Supply. I don't see date codes, but I have only seen one speaker. The tubes hang upside down and are a bear to get back in, so I haven't pulled them yet. It has been recapped at some point, but it needs filters at least, as there is considerable hum in the audio. The handle is broken/gone, but I think a guitar amp handle will work just fine. It needs one of everything, but overall, it is not in bad shape. The paint is sticky from cigarette smoke at some point and the grille cloth is nasty. The cabinet is a textured aluminum that can be disassembled, washed in a parts washer, walnut-shell bead blasted, then repainted. I want to see if Gary can provide a cartridge that will work before I put more time into it. Pictures are in production, but you get the text first.
I think I have the same or very similar unit I bought back in 2017. I've debated whether it's worth putting time and money into it, or I should just turn it into a portable liquor cabinet.
As you can see in the picture, a golden screwdriver has been inside of it. Nicely tape-wrapped electrolytic can stuffed in the corner.
When I first bought it, I did a quick search and uncovered some very unpleasant posts about these. A few threads (one I think on Audio Karma) had the theme that these have an objectionable "hum" even when restored that no one could figure out. I don't want that after putting effort into a project.
Any thoughts Greg????? Oh, and I do have the speakers, they are just removed in the pictures.
- GE_rear.JPG (96.58 KiB) Viewed 34454 times
- GE_front.JPG (93.9 KiB) Viewed 34454 times
Well, Doc, seems like with stuff like this, if you ask ten people you get eleven different answers. All I can testify to is the experience I've had with mine. The GE Trimlines are so ugly, they are cute. And they are fun to mess with, lots simpler than Magnavox.
MIne has a fairly bad hum. I have bridged the caps and the hum diminished. Some is still there. I blame that on the bum cartridge. The caps are supposed to be on shorter wires up in front of the chassis, behind the knobs. "Happy hands at home" moved the filter cap to back behind the chassis and the wires dangle too close to high-gain wiring. That may be part of it. Gary has a cartridge for mine and has advised that the Ronette cartridge "does not track well, so don't play modern stereo records on it, only older stereo or mono records". I don't know how new of records he is talking about, but what I'd play on it is 45's or 78's. I want mine fixed just because it's an orphan and even orphans deserve a little love. And I have the series that my friend Don gave me. Is it "worth" fixing"? Probably not in monetary value. Other than the cartridge, mine will be a reasonably cheap fix. I have to start somewhere. I can't troubleshoot the hum until I get a known good cartridge.
All the GE Trimline stereos and the bigger RP-1590 stereo that I have all use massive capacity in the filter capacitors. 100uf is common for the input filter cap with a 70uf for the output filter and a 70uf at 50 volts for the cathode bypass cap. The RP-1590 I did for Don had a hum I didn't like, so I put a 150uf input filter cap in it and cured that situation. I don't believe GE designed a hum into their stereos. I wonder if the chintzy PCB chassis they use, although they work astonishingly well, are so flimsy and thin they don't do a good job of shielding high-gain circuits. I also can tell you that lead dress is really important when you are dealing with GE stereos.
Are the speakers connected through the hinges?
No. They use hardwired wiring that looks like lamp cord, only smaller. I'm guessing 22 or 24 gauge, unobtanium as far as I know. It gets quite brittle and is typically found broken. The RP-1590 uses guitar plugs on the ends of the wire, another delicate setup. There is typically enough speaker wire stuffed into the speaker enclosures to place the speakers across the house from the stereo. The hinges are riveted to a single-strength aluminum panel, not reinforced. If the speakers are impacted or if the stereo is lifted by the speakers, those hinges bend the aluminum, then they won't latch back to the main cabinet.
Thank you for your response Greg, but I can't say it instills a lot of confidence in me.....electra225 wrote: ↑Sat May 06, 2023 4:22 am Well, Doc, seems like with stuff like this, if you ask ten people you get eleven different answers. All I can testify to is the experience I've had with mine. The GE Trimlines are so ugly, they are cute. And they are fun to mess with, lots simpler than Magnavox.
Does sound like this "hum issue" is real. I wonder what Gary wants for one of those cartridges currently? I really hate to spend $$ and having a 60Hz generator with loud speakers when I'm done.....
Maybe if that Electra225 guy gets his done first and reports back on the good and the bad, it will help me decide!
I understand that Gary wants $28 for a cartridge. I'm going to fix mine regardless. I'm not going to hype it as being better than it is. It is a cheap stereo with a crystal cartridge, so there is that. But it is also the entry-level issue to the Trimline series, which GE built for eons, even more in solid state versions. I have seen several of these little stereos and have never seen one with the original or correct handle. You are certainly welcome to follow along with the restoration of mine. I understand not putting money into something you feel going into that you won't enjoy after it's done.
The jury is admittedly still out on the hum issue. I want to return everything to correct, operating condition, then see what I have. I'm not expecting perfection. I learned to live with old cars, warts and all. I like to apply that procedure to old record players, as well.
In the tube Trimlime stereos, GE hung the chassis upside down, so all the tube heat could bake the already delicate, heat-damaged PCB chassis. There is a metal shield covering the chassis. I don't know whether it's there to shield from heat, to prevent hum, or both. I don't know how it's mounted, never had one out to look. One has to wonder if that shield is grounded to the chassis. That shield seems to me like a good source for hum, if it got distorted some way and contacted something to introduce hum. Heater-to-cathode shorts are on the list of considerations. The used a cathode bypass cap, even in this little stereo. Zenith liked to use the output filter cap for cathode bypass. The PCB chassis notwithstanding, GE got a lot of performance out of fairly basic and minimalist components. I can't believe they designed a system that was prone to hum. They used "deluxe" components such as 7189 output tubes and cathode bypass caps in "price point" equipment.
Okay, Doc, here is the "skinny" on the little GE Trimline stereo....
First, the date codes on the tubes are for the 48th week of 1962, so that makes it a 1963 model. So far, this one and the RP-1590 are both 1963 models....
Next, I have changed the filter capacitors and the cathode bypass cap. I have tested the tubes, for emissions, shorts and life test on my Hickok 648-S tester. All good there. I have cleaned the tube sockets and have made sure that wires carrying AC are not routed anywhere close to high gain audio circuits. I have pulled the metal shield up and found the PCB in almost perfect condition as far as burning and that goes. As far as I know, I'm ready for a cartridge.
I will tell you that the amp in this little stereo is not silent when it's idling with no signal. But I can honestly say it's no noisier than the amp in the Maganvox I did, nor the one in the little Truetone player I'm doing the Tolex on. I can't call the noise hum, exactly. More like hash you would hear with an open mic. I don't find it objectionable. This little amp is not as quiet as a Magnavox, but it doesn't have the filtering a Magnavox amp does. The Magnavox, the Truetone, and this one all have hot chassis amps. The amp is no noisier than an AA5 radio between stations, I checked three handy to get to for confirmation. I used two 100uf @350 volt electrolytics and one 47uf at 160 volt cathode bypass electrolytic. Due to the tall spindle on the changer, the filter cap on this stereo belongs behind the amp, right where somebody put it. There is a hole there for the bolt that held the clamp on the original filter can. I have some pictures to post after I get them loaded to my computer.
Thanks Greg, I appreciate the efforts. I would be interested in seeing those pictures!electra225 wrote: ↑Sat May 06, 2023 9:49 pm Okay, Doc, here is the "skinny" on the little GE Trimline stereo....
I find it funny (both ha-ha and in an ironic way) that both of our machines have the electrolytics so hastily "thrown" together at the rear by quality repair persons! Maybe that was standard operating procedure on these when they came in for servicing. Ha!
From what you are describing, it sounds good so far. I'm almost wondering, (as I did years ago when I did some internet searches) on these models that maybe something strange happens in them, causing the wiring to the cartridge to degrade, (specifically shielding or lack thereof) and causing them to act like antennas picking up objectionable hummmm..........Hmmm.
Just thinking out loud. I haven't done any tear down on mine other then popping the back off to take a peek. I have a bit of renewed interest this as it is taking up a lot of space and I'm cleaning up and downsizing my "hoard". It's either going to get revived, or "chucked".......
Pictures of the little GE stereo. I took a picture showing the speaker wires, as there was a question about those. The balance of the pictures are just general things I tinkered with today.
I have a 1961-2 G.E. that has an all steel frame, including speaker
boxes.
It does have speaker connections through the hinges, but you can
also use the extension wire inside the speaker boxes.
When the speakers are on the hinge, there is some noise/distortion
in the speakers.
When removed, the speakers are OK.
The R speaker still has some distortion, and I need to switch out
the original GE cartridge to see if that helps.
I'm sure it's been several years since I restored that amp and
V-M changer.
The dis-assembly to get the amp out was a bit of a Rubik's Cube.
boxes.
in the speakers.
V-M changer.
GE made several models of Trimline stereos almost alike, but with little differences. The one I'm working on does not power the speakers thru the hinges. I don't know if the other ones I have do or not.
Thank you for the pictures Mr. Mogul!
Wow, so the filter capacitor really was just "put" right there at the edge of the cabinet! That explains why the Greg's machine, and my machine just have the replacement capacitors just "tossed" to the rear.....
Greg,
Any updates on your project?
I think I'm "officially" not going to spend any real time or money on mine. The deciding factor was running across this video with the link that was in the comments section. Seems these are just a poor design with inherent humming.
I've now seen multiple posts about the unacceptable level of hum even in "restored" units. How GE ever released this to the public is beyond me.
Maybe I'll do something custom with mine, or just part it out....
Here's a video and here is the link that was posted in the comments of this video. Hopefully this will help someone on this board.
https://youtu.be/n_yOe9q3ssM?si=L5apQGs-kXpV4su8
https://www.diyaudio.com/community/thre ... ms.265296/
That YouTube guy is careful, but he really needs an editor. We really don't need to watch him check continuity on each one of the phono leads.... I finally fast-forwarded to see how it turned out.
My GE stereo has been put on the back burner for the time being. I put a different changer in mine to check the hum issue. Maybe my standards are low, but I don't hear the hum in mine. I used a changer with a ceramic cartridge. The volume level was listenable, but you couldn't kill drywall with it. My plan right now is to fix it. And, if there is some hum, and if it is an inadequate design, that is part of its personality. Magnavox built $1000 console stereos and left out the bass, so price and brand prestige doesn't necessarily guarantee pristine performance. Doc, your stereo is in nicer shape than mine.
This little Trimline stereo has a Voice of Music model 1235 changer. This changer is mechanically identical to the model 1245 changers in the three more upline GE stereos I have. The difference is the trim is chintzier, it has a 9" platter rather than an 11", and it has a crystal cartridge riding at 10.8 grams. I decided to go thru the changer, and to also order a new cartridge from Gary at VM Enthusiasts. I can lighten the cartridge to 4.6 grams, which should be about right for the new cartridge and also easier on records. I'll play 45's and 78's on this stereo. The other three GE stereos won't have a 78 rpm needle. This changer had a really stiff reject lever on it, so I had to take it totally apart, so I could get to the place where it pivots to clean and lube that part. When the new cartridge gets here, I will see how it sounds. It needs the drive tire replaced, but if it doesn't sound that good, I won't do that.
It will probably surprise you on the way it sounds. Anything GE I have either worked on or heard always surprise me. With you owning all of these GE's and them having VM changers, you are definitely getting the experience all at once. Repetition is a good thing, that way you won't be like me and forget because of the time lapse in between them. Have fun, Greg.
I have hit a snag. I cannot, to save my soul, remove the screw that holds the knob on the end of the flip cartridge. The slot is not very deep, and it won't turn at all. I am going to have to break the knob, then moose that screw out somehow. I have an SOS email in to Gary. I know he probably has the knob, but I don't know about that little screw.
Before you go breaking things, post a photo of what
you're talking about here.
Maybe we can assist.
