Truetone 4DC6107 record player
Post: # 13620Post electra225 »
Pictures to come, here is the back story.
I got my first four-speed record player for Christmas in 1959. I fell in love with this little record player and I stopped in to the Western Auto store almost every week when I was mowing yards to admire it. Mr. Sanders, the owner of the store, always had a record handy, knowing I'd be there. IT cost $24.88 and I still didn't have enough money to buy it by Christmas time. I wanted the record player and a copy of "Calcutta" for Christmas. Mom and grandma both told me it was too much money to spend on such foolishness, that money didn't grow on trees, and that I needed to be grateful for what I had, which was mom's old 78 player, circa 1946 that I still have also.
Christmas Day came and I didn't see any packages under the tree big enough for a record player. I reckon the disappointment was showing on my face. Everybody opened their presents, we had supper, the adults enjoyed cigars and adult beverages, us kids ate popcorn, still no record player. Then granpa said something about it would be nice if I would fire up the "Victrola" and favor the family with some Christmas music. Grandma handed me a record, an LP, Lawrence Welk's new Christmas album. I told grandma I couldn't play that record on mom's old record player. Grandpa came walking into the room with a paper sack under his arm. He handed the sack to me and asked me to see what's inside. There was my record player! And, on the platter, was "Calcutta". Grandpa had bought the record player in June and had been hiding it in his machine room all that time. I'd been in that room hundreds of times since June. The sack with the record player must have been sitting on a shelf, and I'd been staring at it all that time. I dragged that little record player everywhere I went. I put thousands of hours on it. The tone arm broke a couple years after I got it. It spent too many years in my storage shed, so it is in sad condition. It will need all new Tolex and one of everything else. It is your basic one-tube wonder with a 4" speaker mounted on a cardboard speaker board. The grille cloth is the fanciest part of the whole thing, something I'll try to clean and save if I can. The motor mounts are hard as a rock, the drive tires is just as hard and makes a lot of noise in operation. The controls are dirty. I recapped it and got it going again and it really doesn't sound any worse than it ever did. I may try to add a larger speaker when I go back together with it. It's really not worth restoring, it's just a kiddie player, but, boy, what memories that little thing holds. I still have "Calcutta" the original 45 rpm version I got with the player and also the Christmas album grandma bought. That was the first record I ever played on this record player.
Re: Truetone 4DC6107 record player
Post: # 13622Post TC Chris »
Yours is the equivalent of my first 4-speed, the RCA suitcase model I restored a while back. 4" speaker, two knobs, one tube, "captured" 45 rpm adapter on the turntable. The lowest of the low-end devices, but yours at least has the speaker firing forward. Mine has the advantage of the steel case with some sort of bonded vinyl.
For those who missed the excitement, mine is here:
https://www.youtube.com/watch?v=zrc0enXp8AY&t=57s
Post: # 13624Post Hi-Fi-Mogul »
Greg,
That is a great story, right out of "A Christmas Story".
Is your Truetone the same one as this ?
https://www.ebay.com/itm/192601369665
Post: # 13627Post electra225 »
That's it. Mine has the "Truetone" in the lid in block letters, rather than script. Mine may be a nudge newer or older than that one. That one is in better shape. I think that model started in 1957 and lasted until about 1961 or so. Wells-Garnder is the alleged producer, although I have yet to find any EIA codes of any consequence. The motor mechanism and the chassis are both riveted to the motorboard. The hinges and hardware use the same goofy split rivets the Magnavox had. I'll dig them out this time rather than doing as much damage to the cabinet then have to fix all that.
Post: # 13632Post Firedome »
Ah.. nostalgia.
Wasn't Truetone a Western Auto brand?
Post: # 13637Post electra225 »
Yes, Truetone was Western Auto's house brand. Most of their stuff was made by Wells-Gardner. I'd guess at this point, my little record player was not. Pretty cheaply built when you get to looking really close. I have some of the old covering removed. It was more of that wallpaper-like material like was on the Magnavox I redid. This cabinet is in better shape and appears to have been built more sturdy. There is a support for the motor board that is over the top of one of those blamed rivets they use to hold on the hardware on the cabinet. I had to unglue and remove that support so I could remove the hardware. These rivets are smaller and tougher than the ones on the Magnavox cabinet. I've had to use the Dremel tool to grind several of the rivets off. They are so buried in the wood I can't get them out otherwise.
Post: # 13643Post Hi-Fi-Mogul »
Vol and Tone controls, two tubes.
That's not a bad set-up for a small player !
And what a nice, complete schematic and parts
list provided inside the cabinet.
Post: # 13644Post electra225 »
C5 is listed as a .05 at 400 coupling cap. The cap that was in the amp was a .1 at 600, so I replaced it with that value. The ends were swelling in both of the coupling caps and the filter caps had considerable leakage. There is actually a cathode bypass cap in that little amp. 20uf at 150 volt which is a rather uncommon value. Typically we see bypass caps at 25 or 50 volts, not 150. I'm trying to figure out how I can put a bigger speaker in it. The cardboard speaker board has holes bored in it for the speaker and the speaker is riveted to the board. They liked using rivets in this little player.
Post: # 13673Post electra225 »
I have all the covering off the lower part of the cabinet. The wood is in great condition. This little record player cabinet uses finger joints in the cabinet, not just glue and good intentions like the Magnavox cabinet was. All the joints that aren't finger joint are tongue and groove, nailed, then glued. Those blamed rivets they hold the hardware on are lots harder to remove than the ones in the Magnavox were. These are steel, the ones in the Magnavox were aluminum. They are also smaller and harder to dig out. I will start on the lid, but can't remove everything until I get the decals repopped. Maybe I can take them in next week to get that done.
Post: # 13683Post electra225 »
Boy, you have to take this silly thing ALL apart to put Tolex on the motorboard. Everything is riveted on, so I have to cut those hard rivets out with a Dremel and cutoff tool. I hope I haven't ruined it.
Post: # 13791Post electra225 »
I'm in too deep to stop now. I have it apart as much as it can be taken apart. Everything is off the motor board. I have the covering off the motor board. Everything that is rubber is hard as a rock and came apart when I pulled the motor out. I need to get a decal made for the lid. I have enough glue left from the other project and I have enough white to do the inside of the lid and to cover the motor board. All I will need is the silver Tolex and the red Tolex. This is a ridiculous amout of work and expense for a kiddie player. I believe I'll see if Gary has a new tone arm and cartridge for it. Just as well be all in..... ;) ;) :oops: :roll:
Post: # 13825Post electra225 »
I have cleaned and lubes the speed changing mechanism. I have cleaned and lubed the motor. I have installed terminal strips to connect the cartridge to the amp. I have installed a terminal strip for the output transformer to speaker wires and put terminals on the speaker so they can be disconnected if I want to remove the chassis for some reason. I believe the cartridge is still okay, although testing shows it's not. I get hum when I touch the connections on the back of the cartridge. I get noise in the speaker when I drag my finger across the needle. I rigged up a better 4" speaker to hopefully enhance the sound. I've done all I can do electronically and mechanically until I get the Tolex on the motor board. Then I can test more thoroughly. I haven't found black piping the correct size yet, so the search is on for that. Oh, I almost forgot. I put in new motor mounts.
Post: # 13827Post Hi-Fi-Mogul »
That sounds like good progress, Greg.
I look forward to another showroom product !
Post: # 13828Post electra225 »
Thanks for the kind words, Mr. Mogul. I took some pictures. This thing is so simple, yet so complicated as far as getting it apart. It was all riveted together. It was not intended to be worked on.
The speed control mechanism cleaned and greased really well. I wiped much of the excess you see here off.
This is all there is to it....
No more wall paper covering...
Post: # 13831Post TC Chris »
That case looks kinda nekkid....
Post: # 13838Post electra225 »
Now that the electronics and mechanicals are almost done, it's time to take this project to the Cabinets and Grille Cloth board. Please join me there..... :D
Post: # 13861Post hermitcrab »
Going to tolex this one?
Post: # 13863Post electra225 »
Yes. I'll make patterns for this cabinet. All the side pieces are angles.
Post: # 13968Post electra225 »
The cartridge has decided to go kaput on me. There are apparently no new mono crystal cartridges for kiddie players in existence. What do people do? Looks like my best option might be the Pfanstiel P-228, which is stereo with half-inch mount. The one there now is a flip cartridge. Could I mount the P-228 in the original tone arm, using two-sided tape or something like that to hold it in? I would glue the original cartridge flip handle to the tone arm so it would LOOK original. I haven't measured the tone arm yet. It's going to be a bummer to have the outside all redone, yet be stuck with a bum cartridge so it won't work. What do you wiser than I folks have to say?
Post: # 13986Post TC Chris »
When I did my RCA one-tube wonder, I sawed off the turnover lever mount and glued it on to the new flip cartridge with epoxy. Voila, looks just like it did when new.
