Motorola SH20N "Portable" Stereo
Re: Motorola SH20N "Portable" Stereo
Post: # 13387Post electra225 »
That's a nice one. Mr. Mogul. Another VM changer as well. I like how Motorola did the trim on their equipment. Very distinctive.
Post: # 13390Post TC Chris »
Talk us through that output stage schematic. Looks alike a derived center channel, and two single-ended outputs for the higher frequencies, and I'm guessing they phased the speaker connections so the sound output is in phase. But again, explain how it works. Looks interesting.
Post: # 13391Post TC Chris »
And report on what kind of happy noise it makes.
Post: # 13392Post Hi-Fi-Mogul »
TC Chris wrote: ↑Sun Mar 12, 2023 2:50 am Talk us through that output stage schematic. Looks alike a derived center channel, and two single-ended outputs for the higher frequencies, and I'm guessing they phased the speaker connections so the sound output is in phase. But again, explain how it works. Looks interesting.
Chris, I haven't done my research yet on these "3-channel" type set-ups.
I hope one of our members can give us an explanation.
Post: # 13394Post electra225 »
I don't know how they work the three- channel stuff myself, but I noticed it has self-biased output tubes and some kind of feedback setup. It looks like they use the caps across the bass channel output transformer (coupling transformer ?) as a crossover network, so it passes the higher frequencies to the main speakers. I've read where bass is not as directional as higher frequencies, so they use one bass channel. Kinda on the same principle as sub-woofers are used today. I think that feedback is a type of phase inversion, but don't quote me on that. Where is Uncle Doug when we need him?
Try this. It somewhat explains the feedback circuit being a type of phase inverter. You may better understand the operation of the bass channel after watching this video.
https://www.youtube.com/watch?v=U6By31V9fDo
Post: # 13399Post Hi-Fi-Mogul »
Greg,
You really got that right, from what I've been able to
find searching other forums.
I'm also curious to find out how that 3rd OPT for the
bass speaker is configured.
I have that phase inverter video in my saved
bookmarks.
Time to see Uncle Doug again.
Post: # 13406Post electra225 »
I don't have the parts list for that amp, but, the bass channel transformer looks much the same as the other two. If you will refer to the drawing, the output stage receives B+ from the second filter cap, a 40 uf unit, this goes to the center tap of the bass channel audio output transformer. One leg of the primary goes to the upper output tube plate, the other half of the primary goes to the lower output tube plate. Remember we have low-voltage AC (the signal) riding on high voltage DC in the output stage. Audio (AC) comes from each plate after being in phase by the phase inverter circuit. Audio comes from each output tube to the main channel transformers as well as to the bass channel. Each side goes to one half of the bass channel transformer. The caps across the bass channel transformer primary not only rolls off high frequencies to the bass channel, they also block DC. The bass transformer is drawn like the other two, so it's not an auto-transformer or anything like that. It might have a higher current rating for the primary, since it essentially powers up the other two. The screens for the output tubes are on their own B+ leg. It's sometimes confusing working with low AC riding on high DC. Just remember that a transformer will only pass AC. The DC is bypassed to common negative to complete the circuit.
Post: # 13408Post TC Chris »
I stared at the schematic again. The B+ for each HF channel is supplied via its own output transformer and 1/2 of the bass output transformer, at the center tap. So if I'm seeing it right, the bass channel is P-P but each HF channel is single-ended. What I need to do is print the schematic so I can attack it with colored pencils.
Post: # 13410Post Hi-Fi-Mogul »
Greg and Chris,
I'm posting the parts list and schematic from the Sams.
The Beitman's is a bit busy, but it has good info on it.
Post: # 13413Post William »
Frist, I need to say I wish I had Mr. Mogul's Motorola portable over mine which is model SH12N. Mine sounds good and will blow you out of the room for volume, but it has almost zero bass. Mr. Mogul's will have the bass mine lacks.
Back when Vintage was up and running, I shared my restoration on my Motorola stereo tabletop radio which is model B-1000M. I'm not here to take anything away from Mr. Mogul's post, but I am going to provide the schematic to the B-1000M. It too is a three-channel unit with what I'm thinking may be the same type of amplifier that is in Mr. Mogul's SH20N. For those of you that can read and understand a schematic way better than I can, this might make sense to you. Again, this is just for comparison purposes and if anyone wants to run with my schematic, please start a new thread.
Post: # 13415Post Hi-Fi-Mogul »
Since we're on page 2,
I wanted to let Chris and Greg know at the end of page 1,
I posted the Sams schematic and parts list.
Post: # 13428Post TC Chris »
The other Motorola was similar but with some negative feedback in the power amp.
Post: # 13431Post electra225 »
And Bill's has a different phase inverter circuit and had a cathode bypass cap and bias resistor. The negative feedback in Mr. Mogul's amp is part of the phase inverter circuit. Basically, Motorola wired the bass channel like a push-pull audio circuit. Then they used each main channel like they would with a typical push-pull circuit only with single-ended transformers. They might get more bass feeding both tubes into one speaker.
Post: # 13445Post William »
My Motorola B-1000M radio does have bass, and I'm guessing when Mr. Mogul gets his all restored he will be thrilled with the way it sounds.
