"Corn Silo" Zenith 12s267
tasar
Post: # 13091Post tasar »
Rags to riches.... original owner a UP Mi farmer delivered this Zenith after removing from where dad stored it... bottom of a decommissioned corn silo !!
Bottom round plinth stock had fallen off but matching side provided a sample so I could reproduce on the wood lathe. The curved front corners top to bottom were severely cracked lengthwise, basically 90* radius. Rather than remove and replace I mitigated the crack by gluing and back filling with sawdust and TimerMate wood paste before sanding smooth, sealing. Lacquer would pull this surface so a good place to use Poly grip in this case polyurethane. Heresy you say ? But the poly is rather like slow setting glue and held the wood fibers while retaining the original look. To be officially correct, the poly
Coat was wiped down with dewaxed shellac, the universal barrier coat, one that lacquer will not pull. Following shellac I finished out these corner panels as I do most stripped cabinets using Mohawk "perfect brown" toner and clear gloss tone finisher lacquer also a Mohawk product.
Re: "Corn Silo" Zenith 12s267
Post: # 13093Post William »
Beautiful, Dave and the cabinet looks kind of familiar. :roll: :roll: ;)
Post: # 13097Post electra225 »
Beautiful job, Dave. Thanks for sharing that. I use poly almost exclusively anymore. Done right, you can't tell it from lacquer. You have to work poly to make it right on a cabinet, just like you have to work it on a car body. "Gun run" urethanes are too shiny. You have to dull them down by working the finish. But you had to work lacquer as well, just a different method of working the finish. Shellac is a compound people forget about. It can be used on the interior of a cabinet to eliminate musty or smoky smells. It can also be used as a hedge against fisheye and other finish blemishes. Polyurethane finishes essentially wrap a wooden cabinet in a plastic wrapper. About the only way to damage it is with fire or a bulldozer. I don't understand the hesitancy of people to use the more modern finishes. They like sticking with lacquer. I'm guessing because they are familiar with it and it's easier to work with.
tasar
Post: # 13098Post tasar »
Sorry Electra, your first name ?
Lacquer is expedient and easy to fix, respray etc without the dry time. Scratches easily removed, a rather difficult task with poly, but then I've never experimented with base coat clear coat as with auto finishes.
Dave
tasar
Post: # 13099Post tasar »
Also, not sure if there's such a thing as toning polyurethane, one that would quickly layer, dry and float like lacquer.
Midwest Radios are my favorites, poor man's Scott.
It took me awhile to master the airbrush to achieve the tone overspray, a rather prominent difference with Midwest over the other manufactures. One of the heirs to Midwest lives down the road from me here in Leelanau. I've done some of their museum and home radios for them.... here's my fav Midwest the 1936-18x, 18 tube with a rare factory tweeter. Note the highlights at top shoulders and along front edges.
Post: # 13100Post Firedome »
That is a work of art!! The veneer work and design is amazing!!
One or 2 seem reluctant to share their names for some reason (not Electra btw), perhaps for some notion of security?
I'm:
Roger in NY
Post: # 13118Post hermitcrab »
some of the best stuff comes from old farms and barns ... beautiful restore by the way!
Post: # 13125Post TC Chris »
There's a real exuberance to the 1930s Deco styling. Those were tough times economically and it says volumes about our resilience that we adopted that forward-looking attitude then. Sometimes the designers got a bit excessive but the good examples are striking today.
And yeah, I'll confess an affection for Virgil Exner's best "Forward Look" efforts. Last night I watched a 1957 Fellini film, "Nights of Cabiria," online. In several scenes there is a very handsome 1956 (?) DeSoto convertible, top down, in Rome. It's owned driven by a wealthy movie star.
Post: # 13136Post electra225 »
I'm Greg. Sorry, Dave, I assumed you knew.
Poly for cabinets is not base/clear. I typically use gloss because it's easiest to adjust the sheen on. Scratches in the finish sand out like they would on a car, with wet sandpaper. You can "color sand" and buff it to get the depth and sheen you want. The only thing that will harm a cured poly finish is fire or a D9 dozer. We have cats and the wife has flower pots, if you know what I mean. Spots from such things are a thing of the past with poly. It won't crack and craze like lacquer. It moves with the wood. The only downside I see is that it can take a long time to cure properly, particularly if you do an 18-coat finish like I did on the Stereo Theater. We shot the finish, then let it set almost a year and a half before we worked the finish.
The lacquer vs. polyurethane discussion on radio cabinets reminds me of a similar discussion when it was found that the Model T and Model A Ford guys couldn't get nitrocellulose paint anymore. They all said they'd never use urethane paint. NEVER. Guess what they use now. Yep. Base/clear urethane. Somebody got brave, shot a Model T in urethane, worked it, took it to a show, and the rest is history. I say use what you are comfortable with and give the results you desire. Thanks for sharing your work. :D :D
Post: # 13143Post 19&41 »
Those pictures are great! I would have considered that Zenith to be a write off. That restoration job is wonderful.
tasar
Post: # 13153Post tasar »
Thanks for the kind words, 19&41. Honed skills with many a mentor and experiments. Enough to say there's "more than meets the eye".... finishing has many nuances and remedial tricks ! If anyone cares, I can let some of the "cats out of the bag".
Post: # 13172Post William »
I care, so please Dave, let the cat out of the bag. I have 4 consoles that need cabinet work. Mostly the tops, so any help with top only match restoration would be appreciated.
Post: # 13175Post electra225 »
Letting the cat out of the bag is always good. Inquiring minds want to know. :D :D
If you would care to, please feel free to write a blurb about your woodworking and cabinet repair suggestions in Getting Started, so they can be found later if someone needs to refer to them. :D
tasar
Post: # 13190Post tasar »
Very well Greg, Bill, and others, but don't get all "lacquered" up when most tips are poly-delete. I said "most" !
