I found this today as I was looking on Craigs List. This was quite the unit in its day, and it was sold at a tire store.
https://madison.craigslist.org/atq/d/ma ... 54429.html
1941 Firestone
Re: 1941 Firestone
That is a higher-end device than most Firestone units I've seen. I'll bet it's a good performer. I did smile a bit at the "14 inch" speaker description; it appears to be a 14" max. diameter frame, but only about a standard 12" cone. Several companies pulled that trick.
Re: 1941 Firestone
I thought the same thing, Chris. I have seen that before too and it's usually on a higher end unit.
