Temple model 8-90
Temple model 8-90
I have had this radio for several years. A man I worked for gave it to me. I have had several TRF radios over the years, but this one is the best one. It works well, and looks "old". Circa 1928, this a both fairly typical of a TRF radio, but different in that it has a 15" speaker. The primary of the power transformer as well as B+ are both fused. Typical of TRF radios, this one is more sensitive at the upper end of the dial. It will work for local stations with very little antenna. I put the minimum antenna I can get by with. The advantage of super-heterodyne over TRF is the ability to reject interfering stations. This radio is very picky about tuning if you want to tune in a station between two strong stations. There is no AVC. The volume control affects the sensitivity of the front end, rather than controlling output to the audio stages. This radio has nine tubes, Four # 26 RF amps, one #24 detector, a #71 first audio with P-P 45 audio output and a #80 rectifier. It pulls about 71 watts in operation. Its main claim to fame, besides being the oldest radio I own, is that it still runs its original filter caps in the power supply. Its issues are really stiff controls and the speaker is self-destructing as it runs. I have patched the speaker, then I patched the patching until I can't patch any more. Now, I need to decide whether it will be cheaper to have this speaker reconed, including shipping both ways, or just convert the radio to a PM speaker and buy a choke for the power supply and an appropriate audio output transformer. The filter caps are in a block of that gooey tar stuff. I have new caps on a perf-board ready to wire in when the time comes, if it ever does. The original caps still work just fine.
For those who may not be familiar with TRF. IT stands for Tuned Radio Frequency and was a huge step up from the old regenerative sets, because it offered one-knob tuning. The audio on a TRF set is actually more robust and clean than on a Superhet set because there is no local oscillator to introduce birdies and noise in the audio. The downside is less sensitivity at the lower end of the dial and poor inter-station interference rejection. You have to tune carefully and retune as necessary to stay on the station if you have tuned between two strong stations. I have learned to adjust the length of the antenna which helps with interference rejection. This radio also has a phono input. I like TRF sets myself and this one is my favorite, so the only TRF set I still have. A TRF radio just amplifies the RF signal, sends it to a detector, then on to the audio stage. There is no IF transformers and no local oscillator like in a superhet set.
Re: Temple model 8-90
If the speaker cone is really not repairable, why not make an adapter board for smaller speaker, maybe an 8" PM model, and move the oirginal aside a bit and use its field coil and transformer?
That's a cool radio, Greg, I did not know it had two chassis. Me, myself, I would have the original speaker reconed just to keep it as original as possible.
I need to find someone who will recone that speaker. Suggestions ?
This place may be able to, they specialize in vintage speaker repair and got all the obsolete Altec parts when they (Altec) got out of the "real" speaker business (not the plastic computer crap with their name on it now). Some of their factory personnel went there too I believe. I know a guy who had his Altec 604D reconed there and was very pleased. Worth a shot.
https://greatplainsaudio.com/services/
another option would be improvisation, maybe using a cone intended for another speaker from a supplier and gluing it to the spider and surround ou have. And somewhere on a rabbit-hole trip I watched a YouTube video on making a new cone for an antique speaker.
I have a Victor around 1924 they called them the whale mouth due to the sliding tuning control...it is also a TRF set , as said the signal goes though the volume/RF control , and mine the control is crumbled and gone , would have to find a replacement ... mark oppat says he can make me one ... but I really have no interest to repair it ... it weighs a ton ...and the caps are all potted in tar... no thanks ... someone painted a coating of glue on the speaker which made it stiff as a board ...
Ack!!My reply just disappeared! Trying again....
Those Victors are famous. They are from 1929-30, right at the end of the TRF era and just as the Depression was hitting. They have a complex tuning linkage that allows precise alignment for good performance across the dial. (Hence the title "microsynchronous"). They were the peak of TRF technology. The separate chassis for amp and power supply has a P-P output with type 45 tubes. They are noted for superior sound quality among radios of that era. I have the radio-phono model, the RE-45.
http://www.victor-victrola.com/RE-45.htm
https://www.radiolaguy.com/Showcase/Con ... 0RE-45.htm
https://www.radiomuseum.org/r/rca_victo ... re_45.html
This is my oldest phono console! They also sold a radio-only model that I think is R-52.
I have a friend that is into Electrola phonographs. Same vintage as these radios and the electrolytics are packed in tar. He is so fussy that when he is done it looks like it just came off the assembly line. Cans opened up, tar removed, new electrolytics and tar replaced. Anything it needs to make it look new he does. And when done, they sound incredible.
Ask him if he would share knowledge. Mine needs restoration. I did the cabinet 30 years ago and then got into job change and move so the electronics never got done.William wrote: ↑Wed Jul 20, 2022 11:24 pm I have a friend that is into Electrola phonographs. Same vintage as these radios and the electrolytics are packed in tar. He is so fussy that when he is done it looks like it just came off the assembly line. Cans opened up, tar removed, new electrolytics and tar replaced. Anything it needs to make it look new he does. And when done, they sound incredible.
Bill, perhaps your friend would enjoy sharing his knowledge with us on this forum?
I will reach out to him and inquire.
I have had several re-coned by "Sound Remedy" soundremedynj.com , 60 miles away from me, yet shipping is still expensive. I have been very impressed by how the Philco 10-12" speakers came out and it was less than $100 each for a professional job.electra225 wrote: ↑Sun Jul 17, 2022 6:26 pm I need to find someone who will recone that speaker. Suggestions ?
By the way Greg, I have that same radio
Temple of Chicago was confused with Temple (or Templetone) of Connecticut.
I would say this model of TRF radio is worth rejuvenating if you get the chance to do it. I am impressed by how good it sounds when it has no tone controls of any kind and the volume control is in the RF stages. The huge speaker helps, of course. Not many early radios with a 15" speaker. I have never really had any performance issues with this radio, although I have played it considerably. The speaker is so fragile I don't want to run it much until I get something done with the speaker. Here is "good radio signal" country, it plays dependably by using my little metal fan as an antenna. Too much antenna makes the stations run together, on top of one another. If I use less antenna, that works better. Many times, just a test lead hanging off the antenna terminal is all I need. I never have grounded it, that might make it actually work better.
Thanks for the recommendation of a speaker repair place, everybody.
I don't know much about Temple of Chicago that built this radio. My understanding is they are earlier than Templetone that you mentioned. This is a well-built radio, much on the level of Stromberg-Carlson and the better radios of the day. The plating and the finishing on the chassis is still very nice after nearly 100 years. This radio spent maybe 40 years in a storage closet in an old auto repair facility in Tempe, AZ. Somebody let a broom fall and poke a hole in the speaker and destroyed the grill. I made a new grill and patched the hole in the speaker. I've had the radio probably close to 30 years myself. The man who owned the shop was going to restore the radio, but we all know how that goes. He got aggravated when the broom damaged the radio, so he was going to toss it. I asked if I could buy it. He loaded it into my rig and gave it to me. It worked as soon as I got it home and plugged it in. I ran it for several years before I did anything to it. The wires running from the two chassis was in pretty tough shape, so I used wire I had used for making power accessory harnesses in cars to remake that wire. It doesn't look factory, but it works. Now the speaker is getting so delicate it will be my next thing. I have recapped the chassis, performed an alignment, (a different task that on a superhet) and make new filter caps on a perfboard so they can be wired in if I ever need them. I'll run it on its orginal caps as long as they are still good.
I have the one without doors... the cabinet is fair... 2 chassis and 45 outputs ... unfortunately it will probably end up in the dumpsterTC Chris wrote: ↑Wed Jul 20, 2022 11:13 pm Ack!!My reply just disappeared! Trying again....
The #45 output tubes are worth far more than the radio. It is sad when old things end up in the dumpster. In reality, we can't save them all. TRF sets make us appreciate the superhet sets that came later. They are fun to tinker with, though.
There is essentially no market for a TRF set. Collectors either want the earlier multi-dial sets or the later superhets. That's too bad.
AM reception at night might be similar to a 4-tube super-heterodyne (AA5 minus the IF tube), sound very interesting.
DX-ing is a challenge with a TRF set. You either have too much or not enough antenna. I used to use a 24' aluminum extension ladder for an antenna for TRF radios. I could extend the ladder if I needed more antenna. The inability to reject adjacent stations with a TRF is another consideration. The Temple radio I have is much more sensitive than a 4-tube superhet.
Seems to me that Heath made a "hi-fi" TRF AM radio for a while. It did not have the superhet's audio response limits. But that was when some stations could broadcast a wide-bandwidth signal.
Well, since I posted last on this topic, I've learned that it will not be cost-effective to have this speaker reconed. Nobody local want to try it. It is an odd size, 14". I got two estimates of places that will do it. By the time I pay shipping both ways, I'll have $300-$350 in it. This is a 1928 TRF radio that the radio snoots all turn their noses up at. It is an orphan brand and is not particularly interesting in design. It works well and I enjoy it, so I decided to try something I read about several years ago online. I used paper towels to essentially make a speaker cone out of that and Elmer's glue. Practically the entire speaker cone is now covered in white paper towels and Elmers white glue. It sounded good with 3/4 of the speaker cone gone, so it can't sound any worse now. If this will get me by, I can live with it. I don't run this radio every day, but it's nice to have it so I can. It is still running its original filter caps, by the way. A nine tube radio that pulls around 120 watts on the KAW. I'll let the glue dry well, then we'll see how it works.
