Edit. The old limit was 25. I changed it to 50 so I don't get so jammed up. I'll probably just get as jammed up as before, knowing me.......
For your information....
I get a lot of Private Messages. I don't know if the rest of you do, but it's important to keep your inbox and sent box cleared. They will only hold 50 messages before they won't take anymore. You can't receive or send a PM until you clean out these boxes if you go over the limit. Not a horrible job, but aggravating if you want to send a message, but find you are locked out. I've had this happen to me a couple times.....
