VM 853 console
VM 853 console
Post: # 1811Post Motorola minion »
I just had a call from a new customer (referred via local Record Connection) who wants her Grandma's console restored. This model was a 1963, but the VM website lists as 1962, selling for $260 new.
From the conversation it was being used recently so, I am assuming a recap and record player (VM 1200 series) phono wheel, stylus etc. Thanks to Firedome, I have the same tuner and changer as spares :P , so I was pretty sure I could do the job.
I pulled Sams 667 - 10 and confirmed the restoration will be comparable to two lower-priced 6BQ5SE Mag consoles in my shop right now. The schematic did not include the stereo tuner.
This was a popular model for V-M.
V-M 853.png (406.88 KiB) Viewed 50944 times
Re: VM 853 console
Post: # 1817Post Firedome »
I'd forgotten all about that V-M... good luck with the restore Dave!
Re: VM 853 console
Post: # 1830Post electra225 »
Is the tuner full stereo or does it use a Multiplex adapter?
Re: VM 853 console
Post: # 1844Post William »
As far as I know, VM did not have a MPX adaptor. Their tuners were either mono or stereo.
Dave, is this single ended, or PP?
Re: VM 853 console
Post: # 1866Post Motorola minion »
I have the spare tuner and it appears to have on-board mpx. The tube chart shows 19 kc pilot and 38 kc doubler adjust coils.
Re: VM 853 console
Post: # 1884Post electra225 »
Got it. Thanks, Dave.
Re: VM 853 console
Post: # 1902Post Motorola minion »
William wrote: Fri Sep 10, 2021 11:10 am As far as I know, VM did not have a MPX adaptor. Their tuners were either mono or stereo.
I missed your post before sending my last. This stereo amp is a single-ended 6BQ5
Re: VM 853 console
Post: # 1903Post William »
That's what I thought, Dave, thanks!
Re: VM 853 console
Post: # 2801Post Motorola minion »
This unit was a very easy restoration. The player had a still-good Euphonics U2 ceramic cart but needed lots of degunking and an idler pulley. I played it all last week on my office console, a Motorola SK112 with twice as many tubes as the V-M, to be sure all was functional and sounded good on even worn records.
The amp got all its electrolytic caps replaced and the multiplex tuner (model 1465) needed cleaning, two electros, one paper cap and at last, a 6C4 tube was gassy. The bill was reasonable and close to the fair asking price for a restored model, considering its not highly-desirable furniture otherwise.
I delivered and reassembled the console in about an hour and the customer had two LP records of her grandma's, ones I am also familiar with like Jackie Gleason's Orchestra and Billy Vaughn.
These fine old sounds really highlighted how good this unit really sounds. She was going to the local used record store right after I was done, the same place that referred her to me. :P
Too bad many of these get gutted for the amplifier alone but leaving matched speakers behind, it will not sound as good with less-efficient speakers. .
Re: VM 853 console
Post: # 2811Post William »
I have one of those gutted consoles, and it's a VM to boot. Speakers and changer are there, but the amp and controls are missing. It does not look like the optional tuner was ever installed. It's model 809 and looks like this:
https://www.thevoiceofmusic.com/popup_p ... &TITLE=809
Someday, I hope to find the correct amp and controls. I have seen them on eBay but I'm not willing to pay the asking price.
Re: VM 853 console
Post: # 2814Post TC Chris »
William wrote: Mon Nov 01, 2021 11:11 pm I have one of those gutted consoles, and it's a VM to boot. Speakers and changer are there, but the amp and controls are missing.
It's a handsome device, for sure. One option, at least on a temporary basis, is substitution.... find an old receiver and drop it in to give the speakers some exercise and your ears some joy.
Re: VM 853 console
Post: # 2836Post William »
Thanks, Chris. It's in storage in my pole barn right now since I have had no luck finding something that will fit. :(
Re: VM 853 console
Post: # 2845Post Motorola minion »
That amp may be harder to find but I will look. I have the original player and stereo tuner I could mail you tomorrow!
Re: VM 853 console
Post: # 2863Post William »
Wow, Dave, you have the changer and tuner. How did you end up with that and not the rest? Console/amp robbers? Being cheap, it maybe some time before I find the amp at a reasonable price.
Re: VM 853 console
Post: # 2886Post Motorola minion »
William wrote: Wed Nov 03, 2021 12:33 am Wow, Dave, you have the changer and tuner. How did you end up with that and not the rest? Console/amp robbers? Being cheap, it maybe some time before I find the amp at a reasonable price.
The amp had gone elsewhere and I did not see what it came out of. I just grabbed the tuner and changer while it was available. I have two 1465 tuners actually, both stereo. One of them is in a tolex-covered metal case, it was sold as a separate component. That last one was left behind at Kutztown's swap meet two months ago. Let me know your ideas but I would find an amp like a Zenith 5B29, Silvertone or RCA with SE 6BQ5 that has its preamp/controls built-in, not in the tuner chassis.
Re: VM 853 console
Post: # 2888Post William »
Thanks Dave. According to Gary at VM, my VM console had a separate amp that sat in the bottom of the cabinet and a kind of preamp control center that was top side next to the changer. The tuner would have been a separate component that mounted next to the controls and just plugged into those controls. Each company did things "their" way, and for all of us in this hobby that is a good thing. Like cars, if all were the same it would be boring.
Re: VM 853 console
Post: # 2891Post Motorola minion »
The amp in the 853 and tuner drop-in from the topside. The selector-volume-tone controls are built in and included a 6EU7 on a small PC board, fully shielded all around, even the bottom of the amp had a stout, ventilated cover.
The amp itself looked awesome fully shielded and very neat layout of OPTs, power trans and tubes. So I understand its appeal as a separate component.
